LabWindows/CVI
¨How to set the "FM rate" of the E4421B instrument(Agilent) through IVI on LabWindows/CVI
Sorry for my english. I'm basically frenchspeaker. I hope I will use the good terms.
My question:
In LabWindows/CVI 2012, what is the "IVI" function which allows us to set the "FM rate" as well as the "FM Waveform" of the E4421B Signal Generator ????
(3,133 Views)
when you expand the tab "RF" that is listed unter "Configuration" then you will find some
functions. One of them is agesg_ConfigureRF.
Then there is another function -> agesg_configureFM where you can specify your modulation source..?
At the path where you installed the drivers you can find a help document. -> agesg.chm
This document will provide you with lots of infos.
Are this infos helpful for you?
Or could you please discribe your problem with more details.
Thanks a lot.
Andreas K.
NI Germany
(3,120 Views)
