LabWindows/CVI
How to solve this problem?
When I debug the program,It tips“link error”,How to solve the problem?捕获.PNG
(4,674 Views)
Accepted by JackeyHans
If you want to use the progress bar instrument you need either to load it into the Instrument folder (Instrument >> Load... menu item) or install it as a library by selecting Library >> Customize... menu item. The first option is useful for an instrument that you use only in a single project of yours or a few ones since you must manually install it in every project you want to use it, while the second option makes the tool available for all projects you are working on.
(4,651 Views)
Thank you for your help!Very Good!!
(4,644 Views)
Could you detail how to bring the progress bar  instrument  installed in the library, which is what you said the second approach, where are you off to find. "fp" format file, it is better to the appended drawings, thank you very much for your help!
(4,624 Views)
(4,618 Views)
Loading an instrument in the library menu is quite straightforword: execute Library >> Customize... menu function and the Customize Library Menu dialog will appear on screen. On that dialog click on Browse... button and navigate to the instrument folder, then select the appropriate .fp file and click Ok to load it into the library list. Repeat the process for every instrument you want to add to the library.
After dismissing the dialog, restart CVI and the instruments will appear in the library menu and will be usable in your projects.
(4,611 Views)
JackeyHans ha scritto:
This question has been reposted as a new thread: discussion follows here
(4,605 Views)
