Hi, MCS_T,
Usually this error indicates you're not statically linking to the dll correctly. You need to create a dll import library in CVI to call the dll. If you already have one, maybe it's outdated. After you have an import library, f you still get this error, it would indicate that the function may not exist in the dll.
Song D
Song Du
Systems Software
National Instruments R&D
