LabWindows/CVI
I cannot build a dll from CVI to use with labview
I am really not an expert at programming and I need some help to make a labview driver using a CVI file. When I use the import tool in labview, it asks me for a dll file that I do not have and that I cannot build. "ke706_32.DLL"
The CVI drivers for the KI 706 Switch are available on the website but I attach them with this message. Please help! If some body could make this file for me that would be great!
Thanks in advance.
(4,674 Views)
Attached you can find the dll I built for you. Copy the dll in the same directory as the .fp file, then it should work.
(4,662 Views)
Thank you so much!
It's very helpful to get it this fast; hopefully I'll learn how to do it myself soon.
(4,649 Views)
I found this CVI code from a distrubutor after searching the net for couple of months.  I have never used NI CVI before and I dont intend to use it either.  I like programming in Labview.  I was wonding if somebody can help me convert this CVI code to a dll.  When I use the import tool in labview, it asks me for a dll file that I do not have and that I cannot build. "ke706_32.DLL"
I have attached the drivers for the WGPCM4 with this message. Please help!
(4,417 Views)
Hi lizkingx,
I have built the DLL for you. It compiled without any errors. Just some warnings about unused variables and I cleaned them.
See the zip file in the attachment. I have included the LIB file in case you need it.
Hope this helps.
S. Eren BALCI
IMESTEK
(4,398 Views)
Thank you very much for your help ebalci.  Now how do I use this dll in labview.  Do ypu know how to?
(4,269 Views)
I am sure there is lots of information about this in LabView help, in your computer, and in the NI website.
Being a CVI fan, I do not know much about LabView. Smiley Wink
S. Eren BALCI
IMESTEK
(4,245 Views)
