I Cannot Find the header file "dataacq.h" in labwindows CVI
Whenever i try to run a LABWindows CVI application that includes data acquisition, and i include the header file nidaqex.h, the program will not compile because the header file dataacq.h (which is called by nidaqex.h) is nowhere to be found. I am using labwindows cvi 6.0 and NI-DAQ 7.0, could that be the cause of the problem
(3,305 Views)
Hello
Make sure you have added CVI support for DAQ when installing the DAQ driver. These files are part of traditional DAQ, so you can just start up the DAQ installer and select the option for CVI support from the Traditional DAQ feature tree.
This should give you all the required files
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,305 Views)
