Whenever i try to run a LABWindows CVI application that includes data acquisition, and i include the header file nidaqex.h, the program will not compile because the header file dataacq.h (which is called by nidaqex.h) is nowhere to be found. I am using labwindows cvi 6.0 and NI-DAQ 7.0, could that be the cause of the problem
