LabWindows/CVI
I am having issues with timeout when reading RS232
I am very new to Labwindows, currently i have a project to fix, the timeout problem when communicating with a DUT. Here is a little part of the long code.  "AA" is just one of the DUT boards which communicates with a controller board and the controller board has the RS232 communication port.  Is there someting wrong with this code?
  GetCtrlVal (StartUpTestsPanelH, StartUpTST_AA_Test, &status);
   if (status)
    SetComTime_Vali (comport, 15.0); /* we have to increase the timeout; the selftest can take 10-20 sec.*/
    Delay(0.05);
    FlushInQ_Vali(comport);
    strcpy( tempstr, "04b4");
    SendCommand(tempstr, 1, 0, 0, 0);
    selfteststr[0] = '\0';
    ComRd_Vali (comport, selfteststr, 131);
    selfteststr[131] = '\0';
    RS232Error = ReturnRS232Err_Vali ();
    if (RS232Error)
     SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_AA_Test,  ATTR_ON_COLOR, VAL_RED);
    else
     Delay(0.5); FlushInQ_Vali(comport);
     CopyString (word, 0, selfteststr, 7, 4);
     if ( CompareStrings (word, 0, "0000", 0, 1) == 0)
      SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_AA_Test,  ATTR_ON_COLOR, VAL_GREEN);
     else
   SetComTime_Vali (comport, timeout); /*restore original timeout*/
   ProcessDrawEvents(); ProcessSystemEvents();
   SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_COMMANDBUTTON_2,  ATTR_VISIBLE, 1);
   SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_COMMANDBUTTON,  ATTR_VISIBLE, 0);
   SetActiveCtrl (StartUpTestsPanelH, StartUpTST_COMMANDBUTTON_2);
(4,363 Views)
Hello Khan,
where do you experience the timeout? When writing or when reading from RS232?
I cannot see what your function "SendCommand" is doing. How does this function know what to do? Especially it does not have a parameter "ComPort" although your problem description says, that you can test multiple UUTs at a time.
Maybe you'd like to provide more source code details?
Another chance might be to have a look at the RS232 sample projects that come with CVI. Modify e.g. the "serial.prj" and check, if you can reproduce the timeout behaviour.
Hope this helps, Guenter
(4,344 Views)
First thing I do is to configure the RS232 from the drop down menu in the program. It works fine, since i don't see an error then a window pops up which is the "Start-Up Tests",  here are the instructions from the procedure to follow.
5.4 Start-up tests
1. Select “Yes” on startup tests window (Figure 4).
2. Enable present system boards then click “Start” to run the tests (Figure 5).
3. All buttons should be “GREEN” (Figure 6). Record the Start-up tests status for
Tables 1-3 in Appendix A. Then click “Close” to exit the Start-up test window.
4. If a button is “RED” (see Figure 7 for
Receiver board problem example), stop
the test. Start board troubleshooting until the problem is solved. Repeat the
Start-up tests steps 1-3.
After basically box turns green the pop-up window has a close button, that closes the window. Now we are back to main program screen.  we choose what board to communicate with, we select the AA (Acc. & Aux board) this a chooseable or scroll menu and then on the side we have click the RB box and PS box whcih turns it to OFF and leave AA box to ON and and DHRF (this the control board that is communicating with our UUT boards) to ON and from the drop down menu choose Common Tool -> Execute Selftest, then it suppose give us the results on a seperate window called "Selftests Results".  When I choose the Execute Selftest , this is were I get the timout error and it says to increse the timeout however incresing the timeout from the RS232 configuration window does not solve the issue.  I will appreciate if some one point me to where the problem may be. Thanks
int CVICALLBACK OnStartUpTesting (int panel, int control, int event,
          void *callbackData, int eventData1, int eventData2)
 char word[10], tempstr[10000];
 int status;
 switch (event)
 case EVENT_COMMIT:
  SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_COMMANDBUTTON,  ATTR_DIMMED, 1);
  GetCtrlVal (StartUpTestsPanelH, StartUpTST_RB_Test, &status);
  if (status)
   /****Receiver section**********/
   SetComTime_Vali (comport, 15.0); /*restore original timeout*/
   Delay(0.05);
   strcpy (tempstr, "03cc");
   SendCommand(tempstr, 1, 1, 0, 0);
   tempstr[0] = '\0';
   ComRd_Vali (comport, tempstr, 259);
   tempstr[259] = '\0';
   if(RS232Error)
    SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_RB_Test,  ATTR_ON_COLOR, VAL_RED);
   else
    CopyString (word, 0, tempstr, 12, 4);
    if ( CompareStrings (word, 0, "0000", 0, 1) != 0)
    else
     CopyString (word, 0, tempstr, 136, 4);
     else
      CopyString (word, 0, tempstr, 141, 4);
      else
       /***add here the RB data demodulation test***********/
       SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_RB_Test,  ATTR_ON_COLOR, VAL_GREEN);
  Delay(0.05);
  GetCtrlVal (StartUpTestsPanelH, StartUpTST_PS_Test, &status);
  if (status)
   /*****Sequencer section*********/
   strcpy (tempstr, "02cc");
   tempstr[0] = '\0';
   ComRd_Vali (comport, tempstr, 292);
   tempstr[292] = '\0';
   if(RS232Error)
    SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_PS_Test,  ATTR_ON_COLOR, VAL_RED);
   else
    else
     else
      CopyString (word, 0, tempstr, 168, 4);
      else
       CopyString (word, 0, tempstr, 173, 4);
       else
        SetCtrlAttribute (StartUpTestsPanelH, StartUpTST_PS_Test,  ATTR_ON_COLOR, VAL_GREEN);
  /****AA section*********/
  if (status)
   SetComTime_Vali (comport, 0); /* we have to increase the timeout; the selftest can take 10-20 sec.*/
   Delay(0.05);
   strcpy(tempstr, "04b4");
   if (RS232Error)
   else
    else
  break;
 return 0;
(4,303 Views)
here is more code, thanks
This is actually for execute self test:
/*******************************Performs the selftest for th MRX boards**************************************/
void CVICALLBACK ExecSelftest (int menuBar, int menuItem, void *callbackData, int panel)
 if (CheckMaxisActiveActionStatus(0) == 1)
  return;
 TurnChksONandDesactivateSend(0);
 strcpy(tempstr, "\nExecuting Selftest for the selected Board. Please wait 15-20 sec...\n");
 SetCtrlVal (panel_handle, SERIAL_TBOX_READ, tempstr);
 SetComTime_Vali (comport, 30); /* we have to increase the timeout; the selftest can take 10-20 sec.*/
 status = InstallComCallback_Vali (comport, 0, 0, 13, 0, NULL);  IsCommDisabled = 1;           SetCtrlVal(panel_handle, SERIAL_TOGGLEBUTTON, 0);  IsCommDisabled = 1;
 sprintf( tempstr, "%sb4", BoardId);
 if (RS232Error)
  DisplayRS232Error ();
  strcpy(tempstr, "An error was encountered. Seftest aborted.\n");
  COMCallbackCntr = 0; IsCommDisabled = 0; FlushInQ_Vali(comport); status = InstallComCallback_Vali (comport, LWRS_RXFLAG, 0, 13, COMCALLBACKFUNCTION_ID, NULL);
  SetCtrlVal(panel_handle, SERIAL_TOGGLEBUTTON, 1);
  ExitMaxisActionActiveState ();
  return;
 SetCtrlVal (SelftestPanelH, SELFTEST_TEXTMSG_8, "Testing...");
 SetCtrlAttribute (SelftestPanelH, SELFTEST_TEXTMSG_8, ATTR_TEXT_COLOR, VAL_BLACK);
 SetCtrlAttribute (SelftestPanelH, SELFTEST_TEXTMSG_8,ATTR_TEXT_STRIKEOUT, 0);
 InstallPopup (SelftestPanelH);
 ClearSelftestPanel(); UpdateSelftestPanel();
 strcpy(tempstr, "Selftest finished\n");
(4,295 Views)
