LabWindows/CVI
UI Localizer (Command-Line or Active-X usage possible?)
For a CVI 8.1 program using about 50 uir-files I need .lwl-files. Because the system is under construction, I am looking for a possibility to automate the using of the ui-localizer. My questions:
1. Is it possible to use the UI-Localizer by command-line parameters, giving the name of the uir-file, the name of the lwl-file and the name of the dictionary files as parameters? I would like to create a batch file, doing all the translations only with one bath-run.
2. Can the ui-localizer be used by active-x?
3. Does any additional information exist about the ui-localizer, the form and layout of the lwl-files, giving me the chance to build my own "localizer"?
Willi
(3,524 Views)
Hi Willi,
unfortunately I don´t have the sources of this tool, but u can just format a textfile like the tool does.
Inspect it in an editor. I did not try, but it should also work.
best regards
Marco Brauner NIG
(3,497 Views)
