I am making changes to my GUI but when I run it a previous version is running.
I cannot see the changes that I have made in my GUI.
(3,807 Views)
If you enabled Embed project UIRs option from the Target Settings dialog, you have to re-build your exe/dll in order to see the changes.
Is that the case for you?
S. Eren BALCI
IMESTEK
(3,806 Views)
No I did not have it enabled. But when I enabled it and then rebuilt it, it seems to be working. Is this the way it is supposed to function. If so thx a million.
(3,804 Views)
Well, if it wasnt enabled, then I cannot see a reason why it did not work as it supposed to.
Are you sure the UIR file included in the project and the one specified in your LoadPanel function are the same?
You can choose your own method.
1- Enable the option and carry only the executable to distribute your application. Do not forget to re-build.
2- Disable the option and carry the uir file together with your exe to distribute your application. No need to re-bıild when uir changed.
S. Eren BALCI
IMESTEK
(3,802 Views)
Accepted by topic author InquiringMind
It seems that I had two versions of the uir file. Once I deleted one it started working correctly.
(3,772 Views)
