I can't change the decimal point from point to comma with the setlocale function
I would like to transfer floating values by DDE from CVI 5.0.1 to Excel. But the digital point in CVI is "." and Excel needs ",". What is the best way to solve this. Thanks Christian
(3,275 Views)
I would change the "," in Excel to a ".". To change it in Excel you have to change it in windows. Go to control panel,regional language options, customize.
(3,275 Views)
That's sure possible, but in my case we have a company standard to use the "," in windows as decimal point and also many users should use this program. Then also these users has to change this. But thank you for the solution.
(3,275 Views)
