This is strange, what I need to see is a log of the DAQ install, you don't actually have to install to get the log.
When you run the DAQ install use the following command line:
Setup.exe /costlog /l*v "c:\DAQInstLog.txt"
Go until you get the message about not having the correct version of CVI and then cancel the installation. You should have a file where specified above, please send me that file so I can find out what is happenging here.
Jeff
NI
