Hi johansep,
I have a few questions that might be able to help find the cause of the problem. Are you using the CVI ActiveX Controller Wizard? What is your ActiveX project doing? Which applications are you communicating with? And which operation are you using that causes the message, "the operation requires that a menu bar be active"? Is your n drive a network drive?
Thanks a lot.
