LabWindows/CVI
I get "Unable to open file 'n:\h3da_dbg_cdb' (The operation requires that a menu bar be active)" when I try to build my project
When I try to build my ActiveX project, I get the message "Unable to open file 'n:\h3da_dbg_cdb' (The operation requires that a menu bar be active)". The compiling and linking goes OK. But this message pops up just before the building should be finnished. Does anyone know what to do ?
(2,809 Views)
Hi johansep,
I have a few questions that might be able to help find the cause of the problem. Are you using the CVI ActiveX Controller Wizard? What is your ActiveX project doing? Which applications are you communicating with? And which operation are you using that causes the message, "the operation requires that a menu bar be active"? Is your n drive a network drive?
Thanks a lot.
(2,809 Views)
