LabWindows/CVI
I have currently Labview 2010, But I designed my program in other version (2009) , now My program does not operate, is it because I used different version to make it, or its about hardware part.
I currently  have Labview 2010, But I designed my program in other version (2009) , now My program does not operate, is it because I used different version to make it, or its about hardware part. last time it was work vey well but now I try it with 2010 but its not operate.
any suggestion?
thanks alot
(2,740 Views)
Hello erfan,
since your question is LabVIEW reated, you should post it to the appropriate board: this one is dedicated to LabWindows/CVI.
In any case, normally going towards a newer release of he developing environment causes no problems, since usually versions are backward compatibles. Adding some informations to your post can help somebody to detect what's happening and give you better suggestions.
What does it mean "my program does not operate"? Are you receiving any error? Have you added some error checking from which you can obtain more details about problems?
Are you using some hardware? Is it working well out of your program (e.g. does it pass MAX tests, can you run some example program?)
Is your program a single VI or a multiple VI? In this case, do child VIs run correctly? Can you reduce the malfunctionment to a single / a few VIs?
If you can find the source of your problem, can you post it or a reduced part of it so that we can examine it?
(2,737 Views)
