LabWindows/CVI
I need CWiviScope information...
I'm using Labwindows CVI 6.0 FULL release and Windows 2000.
What I'm doing is that I plugged a ADC0801 to my parallel port LPT1 (using inp(LPT1_DATA); function) and I acquire data. My sample rate is estimated at 20KHz and I use a circular buffer. I have 3 threads, one that acquire, one that plots on the graph and the last one is used to manage de UI. I was using de CWGraph, but its slow. I would like to use de CWiviScope. But I don't understand how I pass my data to it. And will it be fast enough to display ?
If someone could just explain me how it works to plot on it.
Thank you,
(2,839 Views)
CWIviScope is a hardware interface to a IVI Scope class instrument connected vial GPIB/Serial/VXI/Ethernet. It is NOT a user interface control, it just has a built in user interface to view what is happening on the oscilliscope hardware. There is NO WAY to pass data into it, it gets it's data from the hardware.
Best Regards,
Chris Matthews
(2,839 Views)
