LabWindows/CVI
printing trouble with NIreports
My application uses both PrintPanel and NIReport_Print (using NIReport with CVI 6.0). PrintPanel always works fine, but for some target configuration, NIReport_Print doesn't generate report. The printer spooler is not activated, and no error message is given (nothing happens). This occurs with Windows NT 4 (SP 6) and W98 SE as well.
regards,
Chris
(2,844 Views)
You may be using different versions of NI reports on the different machines. Make sure the NI reports files under program files\national instruments\shared\NI-Reports are the same on the different target machines.
Best Regards,
Chris Matthews
(2,844 Views)
