Hello Jeremy,
I would suggest looking at the shipping example: excel2000dem.prj. This example is located in the following directory for CVI 7.x: ..\National Instruments\CVI7.x\samples\activex\excel.
For previous version of CVI, the example should be located in the following directory: ..\MeasurementStudio\cvi\samples\activex\excel.
This example documents how to open, close, write and read data from xls files. In particular, this example demonstrates multiple ways you can read and write data. For your situation, there are two documented ways to read data from specific cells: (1) Get each cell value in Range one at a time using an offset from the range's top left cell, and (2)Get Range as a SAFEARRAY inside a VARIANT.
Take a look at that example, and it should help.
Thanks Jeremy!
Wendy L
LabWindows/CVI Developer Newsletter
