LabWindows/CVI
I want to acquire data and compute real time. Suggestions?
I want to measure a continuous signal, I use NI-DAQmx, in labwindows, and I have to do much computation. I use a Trigger of 1 second, sample rate of 30kHz, so each second I have a new "array"... suggestions?
(2,944 Views)
Hi No,
you can look at the discussion forum thread linked below where you will be pointed to an example that would allow you to implement what you describe above.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000013F50000&UCATEGORY_0=_318_&UCATEGORY_S=0
AlessioD
(2,944 Views)
