LabWindows/CVI
how to stop MS Windows tasks
Is there a way in LabWindows/CVI to stop all Microsoft windows (XP) tasks? I need to do real time acquisitions!
(3,352 Views)
It is not a particularly good idea to stop other tasks. The best solution is possibly to raise the priority of your process above [most of] the other processes in the system.
The Windows API function SetPriorityClass() is used to do this, e.g.:
success = SetPriorityClass(GetCurrentProcess(), HIGH_PRIORITY_CLASS);
or
success = SetPriorityClass(GetCurrentProcess(), REALTIME_PRIORITY_CLASS);
If you do this, important Windows processes will get reduced or no time, so you should normally return the process priority to 'normal' as soon as possible:
success = SetPriorityClass(GetCurrentProcess(), NORMAL_PRIORITY_CLASS);
You can find more information about this function here.
Martin.
Martin
Certified CVI Developer
(3,352 Views)
