LabWindows/CVI
Triggering NI-DAQmx
I am using NI-DAQmx, and I want to sample at 30 kHz, for example 27 kSamples; I want to do it in a cycle, so I need a trigger (I'd like it to be external). I'd like to have a trigger working like the counter you can put to the graphic panel, but it has to be hardware, to say a digital signal through the PFI0 pin. I've a PCI 6143 card. Thanks
(3,125 Views)
Graziano,
you can find an example that does what you need among the examples provided with the CVI installation. The example is called ContAcq-ExtClk-DigStart.prj and it is found in the folder
...\CVI\samples\daqmx\Analog In\Measure Voltage\
Just use devx/Internal20MHzTimebase as the External clock source.
AlessioD
(3,125 Views)
