LabWindows/CVI
I want to program labview to read a file data from an other code and make graph
if you can give me an example
(3,063 Views)
You'd better post this question in the LabVIWE section of the Developer Exchange.
Anyway, I suggest you to look in the examples shipped with LabVIEW: you can find some basic VI that can help to solve your problem.
In Search Examples >> Fundamentals >> File I/O you can learn how to read data from a file.
In Fundamentals >> Graph and Charts you can find examples on how to graph data.
The basic problem is the format of data stored on file: all is easy if they are in plain text, some moreproblem will arise in case they are stored in binary format.
Hope this helps
Roberto
(3,063 Views)
Depending on exactly what form your data is in, you will be looking at some sort of VI similar to the attached. From my vast experience :=).....the biggest challenge in importing unknown data formats, is whether it's "BigEndian" or "LittleEndian" data...that is...is it sent most significant bit, or least significant bit first. It's a simple matter to reverse the data, and see what gives you a reasonable looking graph. If you have the direction reversed, you will usually have a discontinuous bunch of vertical lines. Anyway...give this a shot, and let me know what happens.
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(3,063 Views)
