LabWindows/CVI
problem with cvi sql toolkit and sqlserver
I want to use the SQL Toolkit (v.2.06) to connect a MS sqlserver(v.200 pro) database.
So the problem deals with DBcreateTablefromMap() when you use previously the function DBMapColumn ToChar!
There is no problem with DBMapColumnToInt function and with a connection withMySQL .
So, The ERROR Message returned by CVI is: " Function DBcreateTablefromMap : return value -10 "
thanks a lot for your help!
(3,511 Views)
Error -10 (DB_DBSYS_ERROR) means that the error was detected by ADO. You can call DBNativeError function to get the underlying error code. Please refer to the KnowledgeBase below:
http://digital.ni.com/public.nsf/websearch/A23525E4DDABF00B86256A940071D9A6?OpenDocument
Mika Fukuchi
Application Engineer
(3,511 Views)
yes, I know it is an error detected by ADO but why it deals with DBMapColumnToInt (there's no error) but when I include a DBMapColumnToChar there's the error message?
thanks for your help
(3,511 Views)
