Home
Community
Discussion Forums
Most Active Software Boards
LabWindows/CVI
Topic
LabWindows/CVI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Best animation tool for CVI ?
gasma1975
Member
04-19-2003
10:58 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I would like to know wich tool or activeX control is the best and easiest to integrate in CVI ?
I've tried the ShockwaveFlash ActiveX, but its crashing CVI and its very unstable ?
I have a simple animation to make the will be running in my panel. Any suggestion ?
Thank you,
Aldrin,
0
Kudos
Message
1
of 2
(3,322 Views)
Reply
Re: Best animation tool for CVI ?
bilalD
NI Employee (retired)
04-21-2003
12:25 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
If shockwave didnt do the trick, you can use just CVI for creating animations. Check out the example under
samples\userint\custctrl\animate\animsample.prj
This should give you a place to start
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
0
Kudos
Message
2
of 2
(3,322 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
