LabWindows/CVI
Best animation tool for CVI ?
I would like to know wich tool or activeX control is the best and easiest to integrate in CVI ?
I've tried the ShockwaveFlash ActiveX, but its crashing CVI and its very unstable ?
I have a simple animation to make the will be running in my panel. Any suggestion ?
Thank you,
Aldrin,
(3,326 Views)
If shockwave didnt do the trick, you can use just CVI for creating animations. Check out the example under
samples\userint\custctrl\animate\animsample.prj
This should give you a place to start
I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,326 Views)
