INET_RegisterPanelAutoUpdate Problems
I cannot get this function to write a .jpg file to my webpage. At the moment I am developing the system on my pc -(ie there is no web, just a file on my c: drive) but the .jpg file is not being written. I am using client pull transfer. I have used the INET_PanelToJPEG function successfully and the server is being opened and closed correctly as the log file shows but I dont get a .jpg file. The same is true when I run the example program cvinet/samples/clntpull.
Please help!!
cheers, tim
(system NT4: 500MHzAMD 128M Ram)
(3,007 Views)
Tim:
The Client Pull and Server Push methods both require support from your web browser. Support for these methods will vary depending on the browser you're using, and sometimes will even vary depending on the version of the browser you're using--this depends on the manufacturer of the particular browser.
Do the Server Push examples work?
Tim, you may prefer to request support from National Instruments Technical Support concerning this matter. You can contact National Instruments support via telephone at 1-800-IEEE-488 or via email at http://www.ni.com/ask.
Good Luck,
Chris W
(3,007 Views)
