LabWindows/CVI
INI instrument driver and fatal run time errors
Hey everyone, I'm experimenting with the INI instrument driver and running into a fatal run time error.  Here's what I know so far:
  1. The runtime error only happens during the very first Ini_Putxxx
  2. It only happens if the target INI file does not yet exist.  After the file is created with a Ini_WriteToFile, then the program will proceed with all my Put functions without any errors.
Ideas?
(3,779 Views)
I found my own solution to this.  It would appear that te Ini_WriteToFile function will not create the INI file if it doesn't already exist, much like OpenFile will.  So instead, I just do an initial check with the FileExists function and then create with the OpenFile (and not forgetting to immediately CloseFile).
Then I can Ini_PutString to my heart's content.
(3,774 Views)
Accepted by ElectroLund
Are you sure about that? I just tried calling these functions in the Interactive Execution window without errors (the destination file wasn't there before the call and has been created without errors):
#include "inifile.h"
static int			error = 0;
static IniText		T = 0;
T = Ini_New (0);
Ini_PutString (T, "General", "Item 1", "Test string");
Ini_PutInt (T, "General", "Item 2", 123);
Ini_PutDouble (T, "General", "Item 3", Pi ());
error = Ini_WriteToFile (T, "C:\\test.ini");
Ini_Dispose (T);
Ini_PutXX functions do not make any disk access, they work entirely in memory; the only functions where the instrument accesses the disk are Ini_WriteToFile and Ini_ReadFromFile. Which error are you receiving? Can you post a sample code that exhibits the error?
(3,762 Views)
Hmm, well that's interesting.  I will try to revisit this soon.  For now, I need to proceed with my clunky work-around.
Thanks, Roberto!
(3,706 Views)
You were of course correct, Roberto. I had forgotten to call Ini_New() before writing values to an ini buffer.  Oops!
(3,655 Views)
