LabWindows/CVI
Ieee754
I have an output from a MAss Flow Controller in IEEE 754 floating point its 42 48 00 and it is supposed to be 50. How does one convert that into 50
(5,458 Views)
Your instrument sends back measures in little-endian format, that is with the most significant byte first. BTW, the number is a 4-byte one: an additional 00 byte must be at the end the string. You can reverse bytes order and simply cast the string into a float, this way ("tmp" is the variable into which you read back from the instrument):
static char tmp[4];
tmp[0] = 0x0;
tmp[1] = 0x0;
tmp[2] = 0x48;
tmp[3] = 0x42;
DebugPrintf ("%f\n", *(float *)tmp);
For a small reference on IEEE754 format, you can look at this page: it's useful to validate conversion algorithms you develop to translate instrument raw data.
(5,452 Views)
That does work but I am trying to concatenate strings and I cannot concatenate that output string with a hex display with the rest beacause the othersa are on normal display
(5,436 Views)
I didn't understand your comment about concatenating: I used DebugPrintf to obtain an immediate printed result of the conversion, but you can substitute it with sprintf to format your variable into the message you need.
Or simply I didn't catch your problem: can you explain it better?
(5,431 Views)
I found a solution thank you very much for your help
(5,415 Views)
