LabWindows/CVI
Imaq_CVI.dll
On W98 I have no problem using Imaq library. On the W2000 OS,
I cannot run anything from the Imaq library. Could anyone
tell me why?.
Thank you.
(2,871 Views)
First make sure that all of the software is installed properly. It should show up under Add/Remove Programs in the control panel. If you are using NI-IMAQ, make sure your imaq board shows up in MAX and that you can do a snap or grab. If all of this works, the software is probably installed properly.
Within CVI, you may have to go to Options>>Library Options and add your IMAQ fp files to your user libraries. The same is true for Vision and OCR.
(2,871 Views)
