LabWindows/CVI
[SQL TOOLKIT] [CVI6] invalid date format
I had to update an application written in CVI5/SQL 200
connected to an Oracle 8i Database via an ODBC driver, into CVI6/SQL 206
connected to Oracle 9i.
And the DBBINDCHARCOL SQL function does not return correct values when i
try to extract date fields.
For example:
DBBINDCOLCHAR(hmst,1,45,date,&status,"") returns "1"
instead of "1/1/2001 00:00:00" that is returned in the previous version
of the application.
if i precise the output format as "dd/mm/yyyy hh:mm:ss", the function
returns correct values, but then i would have to check a large
application to update this.
Any other idea ?
P.-S.: I wonder if that is an UNICODE problem.
(3,214 Views)
I think the problem comes from the ODBC driver. I've got the same trouble with differents drivers for the same database !.
(3,214 Views)
