LabWindows/CVI
In CVI How do I make a panel act like a prompt popup, Ive tried the Installpopup fucntion without the desired result.
In LabwindowsCVI version 7.0. I have created a keyboard panel designed to be used with a mouse to allow alpha numeric data entry without a touch screen or keyboard. I would like to have this panel act as a propmt popup panel. Where the panel is displayed and the callback function displaying the panel waits until the panel is not visable before continuing. I have tried using the InstallPopup function, but the caling calback function contiues to exicute after displaying the panel. The InstallPopup description sounds like it shoudl do what I whant but it does not seem to be working.
(3,206 Views)
See the answers to the question previously asked here
Martin
Martin
Certified CVI Developer
(3,206 Views)
InstallPopup doesn't cause your code to wait: it just installs and displays a modal dialog box. I typically use InstallPopup in conjunction with GetUserEvent and RemovePopup.
GetUserEvent with Wait Mode set to wait will wait until an EVENT_COMMIT is generated. GetUserEvent then returns the panel and control that generated the EVENT_COMMIT.
If your keyboard panel popup has buttons like OK or ENTER or CANCEL, you need to put GetUserEvent in a loop: you'll get EVENT_COMMIT's on letters or numbers clicked as well as on OK (etc.). In your loop, if the control that generated EVENT_COMMIT is not OK, ENTER, or CANCEL, it must be a letter or number: use it to build your string. If the EVENT_COMMIT is from OK or ENTER, return to your calling routine and RemovePopup(0). If EVE
NT_COMMIT is from CANCEL, clear the string (e.g. sMyString[0] = '\0';) before returning.
You may want to set the Shortcut Key for OK or ENTER to Enter, and the Shortcut Key for CANCEL to Esc.
(3,206 Views)
In your loop building the string based on buttons pressed, you could call GetCtrlAttribute() to get ATTR_LABEL_TEXT rather than having a case for each button. E.g. the ATTR_LABEL_TEXT for the A key will be "A". You may need a few special cases for Backspace, Delete, Spacebar, etc.
(3,206 Views)
