LabWindows/CVI
InetFTPGetDir function does not retrieve the whole DIR string
I am trying to get info on the current dir of a remote computer with error= InetFTPGetDir(ftp_handle, dir, MAX_FTP_PATHNAME_SIZE).  This function only returned a partial dir string.  The whole string should be: Current directory is "/EngDIr/".  The function returned: urrent directory is
Any suggestion is well appreciated.
Best Regards
Ton Ng
(4,112 Views)
What version of CVI are you using?
What FTP server are you using?
How are you declaring the dir variable?
There's an earlier message about problems with InetFTPGetDir that didn't seem to get resolved.  http://forums.ni.com/ni/board/message?board.id=180&message.id=24006&query.id=223193#M24006
(4,097 Views)
Hi TonNg,
Also, what is the error code being returned?  Please try running the example program ftpcInt and confirm that this gives the same result.
Cheers,
David Goldberg
Software R&D
(4,074 Views)
Hello Cheers,
I am using CVI 8.0.1 example ftpclnt in the directory CVI80\Samples\Internet\ftpclnt.  The FTP server is VxWorks
The function InetFTPGetDir returned 0 (no error), but I got back an incomplete dir string.  The traffic monitor program Ethereal does indicate that the server sent a complete string.
CVI string return was truncated as urrent directory is  instead of Current directory is "/RAMDEV0/.  Please see attached capture file.
Best Regards,
Ton Ng
(4,063 Views)
Hypothesis: InetFTPGetDir() works by trying to parse the string returned by an FTP 'pwd' command in a farly simple way.
With a typical GNU/Linux FTP server, the string returned is like this:
"/" is current directory.
and you can see that if you remove the first character and copy everything up to the next double quote, you get the directory /.
However, applying the same algorithm to the string the the VxWorks FTP server returns:
would get you exactly what you are seeing.
Which would suggest that InetFTPGetDir will only work properly with FTP servers that act like the GNU/Linux one. Which isn't ever so useful for the other servers.
Martin
Certified CVI Developer
(4,053 Views)
The format returned by the VxWorks server does not obey the FTP RFC 959. Check out http://www.faqs.org/rfcs/rfc959.html. The response to PWD is supposed to be in the same format as the response to MKD, which should be of the form:
257<space>"<directory-name>"<space><commentary>
(4,032 Views)
