LabWindows/CVI
viOpen with string variable
Please can any help -
I am trying to use use a string variable 'IP_Address' in the viOpen command structure
status = viOpen (defaultRM, "TCPIP0::192.168.10.50::inst0::INSTR", VI_NULL, VI_NULL,&Generator);
so that the hard-coded ip address 192.168.20.50 can be a variable read into 'IP_Address'  from user input.
I have tried formatting 'IP_Address' to contain "TCPIP0::192.168.10.50::inst0::INSTR" and then using:
viOpen (defaultRM, IP_Address, VI_NULL, VI_NULL,&Generator);
but get an error 'Invalid Resource Reference'.
Is there any way of accomplishing this?
Many thanks,
Allen Cherry
(4,177 Views)
Your idea should work. There must be a detail wrong, which is not  included in your description.
A guess:
What is the size of the IP_Address string ? Might it be that it misses the space for  terminating \0 char?
(4,172 Views)
The inst0 should be the LAN device name of the instrument.
If you are using the default I think you can leave it out
eg
"TCPIP0::192.168.10.50::INSTR"
Regards
Ray farmer
Regards
Ray Farmer
(4,167 Views)
Markus,
Many thanks - your guess was correct!!
Allen
(4,152 Views)
Ray,
Yes - it does work leaving out the '::inst0'.
Thanks for your help,
Allen
(4,150 Views)
