LabWindows/CVI
Which command (function) in Advanced Analysis Library I can use for least square fit method (ie: Curve Fitting)?
I have to use the Gauss-Jordan elimination to solve the linear equation system when the degree polymonial degree is greater than 1. The problem is I am the end-programmer: means I will receive 3 parameters to do this function:
1. An array of X coordinate of M points
2. An array of Y coordinate of M points
3. The dgree of polymonial request for the approximation (N)
Then return an coeffficient array that contains (N+1) of the polymonial
ie:  arr_coeff = myfunctionLeastSquareFit( arr_x, arr_y, 1);  // where arr_x = [0,1,2,3] arr_y = [0,1,2,3]
Which closest command I should use in Advanced Analysis Library to comply this function?
Note: Just for more info. this function return, will use for the next function:   interpolate(arr_coeff, data);  // where data[5,6]
Thanks for any help
(4,234 Views)
I'm not so fond on matrix calculations as to get its connections with curve fitting, but PoliFit is the function I normally use to perform curve fitting on array of measures; it uses the least square method and returns both the array of coefficients and the curve already fitted. It's possibly what you're looking for...
(4,216 Views)
I did try the PolyFit as you suggested, but the result is not good for order of 3 (3rd degree).
1.  After calling sci_leastSquareFit(...) the db_arrRet contains 4 coefficiences not the same with the General Poly fit.vi in LabView
2. Then after using the values to work with my sci_interpolate(...), the responses are bad ... you can run my attached project to see the weird graph after applying function calls
*) However with Labview: they are working well after applying the Labview result with Interpolate.vi
I do not what I have done incorrectely? Can you take a look ... since you mentioned that you did use them OK?
(4,188 Views)
I'm not sure why you explicitly assign the coefficient values to db_arrM[] in sci_interpolate(), but you have made a mistake with the sign of the fourth coefficient db_arrM[3].
If you comment out the lines:
//db_arrM[0] = -0.27;
//db_arrM[1] = 2.807;
//db_arrM[2] = -0.52;
//db_arrM[3] = -0.02;
then the second graph has a typical cubic shape that is a reasonable match to your orignal curve (see attached screenshot).
Martin
Certified CVI Developer
(4,176 Views)
I second Martin suggestion, confirming that coefficients calculated by CVI PolyFit funcion are the same as those calculated by LV General Polynomial Fit.VI. As an additional notice, every time I compared them in the past PolyFit returned almost the same coefficients as "Add trendline" facility in Excel.
(4,163 Views)
The real story is on Friday afternoon, after trying some thing does not work well, I did assigned those constant values from Labview to verify my functions ... and somehow I mexed-up & forget to remove it! Thanks for pointing out these, now I feel better ... because I did verify many times those functions & could not find the errors (my real program, I call functions not in the same locations in Graph.c ... that was why I did not see those assign in main program
Thanks again
(4,158 Views)
