InetSendMail Error Question
I have a problem using InetSendMail (SMTP sever, From_Email, To_Email, Subject, Message, attachment) function.
If I directly use a string in To_Email position as "xxxx@xxx.xxx" then the functions works well and I can send emails.
However, if I use,
char To_Email[30] ="xxxx@xxx.xxx";  and use  InetSendMail(..) function with  To_Email (e.g. InetSendMail(..,.., To_Email,..,..), then I always got an error -7.
Can anyone give me a advice?
Thank you.
(3,686 Views)
Accepted by Shre07
Try declaring it as:
const char* To_Email = "xxxx@xxxx.xxxx";
Let me know if that makes a difference in your code.
Tanya Visser
LabVIEW Group Manager
(3,644 Views)
 It works.
Thank you.
(3,638 Views)
