LabWindows/CVI
Installing a callback for multiple windows messages and processing EVENT_NEWHANDLE message
Good afternoon all,  I am a newbie to using the Win32 API.  I have two questions:
    • When a single callback is installed to process multiple windows messages, will the install function return the same windows handle for the panel?
    • I also saw noted in the help your panel should handle and respond to the EVENT_NEWHANDLE message.  Does the InstallWinMsgCallback function need to be called make sure your panel handles this message as well?
Thank you for your help.
(4,817 Views)
Hi hortoxn1,
We have a KnowledgeBase Article on this topic that you may find useful:
"How Do CVI Panels Process Windows Messages?"
http://digital.ni.com/public.nsf/allkb/29C12428E7974EEF862565EF00839871
Does that explain what you're looking for?
Steven Gloor
Staff Customer Engineer - CTA, CLD
(4,792 Views)
Thank you. Found some example code too looking at related links.
(4,786 Views)
