LabWindows/CVI
Programmatically setting tab order?
If I add controls using either NewCtrl(..) or DuplicateCtrl(..) to an already existing panel that I loaded with LoadPanel(..), is there a way to change the sequence that the controls are cycled through when using the tab key (or to insert the new controls where I want them in the sequence), or will the added controls always be at the end of the sequence?  As far as I can tell, there doesn't appear to be a way to do this but I thought I would ask just in case I'm missing something.
Thanks.
(5,536 Views)
Accepted by topic author tstanley
SetCtrlAttribute (panel_handle, control_id, ATTR_CTRL_TAB_POSITION, tab_order);
(5,529 Views)
Thanks Wolfgang, I knew I was missing something obvious!  Smiley Happy
(5,511 Views)
My pleasure.
(5,509 Views)
