LabWindows/CVI
Instrument I/O Assistant
Thanks for the valuable information.
I will try this. If timing is a concern I could use a timer to check for new data?
'ComRdTerm' in the serial example has a count parameter, what if you don't know how many bytes there are to read?
Is there a max value?
Thanks.
Message 11 of 13
(1,423 Views)
ComRdTerm terminates either on termination characer received or on number of characters, whichever comes first.
Message 12 of 13
(1,419 Views)
Accepted by NI Nubie
Can you help with the attached file.
After I enter text and hit the <Enter> key I would like the data to appear in the recive window without having to use a button.
I an a little confused about the InstallComCallback and ComRdTerm commands and where they should go.
Thanks.
Message 13 of 13
(1,414 Views)
