 lesc
			lesc
			04-04-2012 12:53 PM
We have a problem with our CVI/labwindows 8.0 program crashing intermittently during a long test run during temperature (12 to 24 hour runs)testing. We cannot reproduce this problem repeatably. We think it might be during the ProcessSytemEvents but we are not sure.
Attached are the Dr Watson log and screen capture of the window error message indicating the problem occurred in cvirte.dll ModVer 9.0.0.348 offset: 0035b15a. Is there some other way to send the user.dmp as our company blocks ftp (the use.dmp zipped up is about 13Meg so it cannot be attached).
Thanks for any help.
Les
04-05-2012 06:12 PM
Hey Les,
Thanks for your post. I have a few questions regarding your set-up:
1) What is the overall architecture of your program.
2) Is there a pattern to when the crashes occur?
3) Has the crash only recently started happening?
4) Have you made recent changes to the code that seem to have brought these crashes about?
In the mean time, I'll take a look over the Dr Watson log and see if I can find any clues in there.
Best,
 D_Biel
			D_Biel
			04-06-2012 10:22 AM
Hi Les,
I sent you a private message through the forums about alternative methods for transferring the file to us for further debugging.
