LabWindows/CVI
Internet Explorer ActiveX - Saving a webpage
Is there a way to save a webpage to a local drive?
I'm actually trying to perform a function based on a field in a webpage, but the ony way I can think to do that is save it as a text file and parse the file for the info I need, so if someone can give me an idea on how to do that, I would appreciate it.
(3,257 Views)
Hi MattZ,
One way to accomplish this would be to download the webpage through data socket. I modified the example program under <CVI>\samples\datasocket\Reader to demonstrate this. You end up with a char[] in memory that you can parse to your desire.
(3,232 Views)
Thanks.  That got the job done.
(3,227 Views)
