LabWindows/CVI
Is ist possible to write Dlls in Lab windows for DAQ KUSB3116 Keithley?
Ihave here to use the Data Auisition KUSB 3116 from keithley.  My question is how can i control the KUSB from Teststand. Are there IVI or similar drivers avaialble?
Is ist possible to write Dlls in Lab windows which I then call in teststand? There are examples from keithley where they use MS VIsual C++, but I have to use labWindows
Does anyone have experience with such problems
regards samuel
(2,930 Views)
That should be no problem. If the examples for Visual C++ are written in ANSI C, you shoul dbe able to compile them in labWindows/CVi as well. Here you can find documents describing how to build DLLs in CVI:
http://zone.ni.com/devzone/devzone.nsf/webcategories/0E97B53AA853A139862567A9005893BE
(2,909 Views)
