LabWindows/CVI
Is it possible to convert strings or characters to enum type during runtime?
I know that it does not make sense, but it would be handy and maybe there is some vicked trick out there?
The issue is that I have a string and I would like to use the characters as indices to access a 2D matrix.
The indices do not follow the alphabetical order (it would be easy to serialize the Ascii codes by reducing their value by A) but
in enum space A=3, B=8, C=1.... etc
Currently I use switch {} and case 'A':  value =3... but this is not economical, I have to have 23 case statements!
Tried some type casting, it does not seem to work
typedef enum  {A=3,B=5,C=1,D=22,E}LetterIndex;
char *string[]={"AAABBBCCCDDDEEE"};
LetterIndex Lind[21];
than assing: Lind[0]=(LetterIndex) string[0]; and get the ascii value of 'A' instead of 3 (as in teh enum, of course becouse of diffrent storage of A and the 'A'
I would wellcome a good idea here...
Layosh
(3,883 Views)
Well if your string definition was replaced with something more along the lines of:
    char string[]={A,A,A,B,B,B,C,C,C,D,D,D,E,E,E};
you might be a bit closer to achieving your goal, but I'm not certain about what you want your final code to do.
JR
(3,877 Views)
to answer your original question, it is not possible to get the enum value from a string in C. (however, the reverse is possible using the stringizing preprocessor operator, but it will not help in your case.)
back to your problem, i can see no problem getting the enum value from a character by subtracting 'A'. here is how i would do it:
// this is the original enum defining the
typedef enum
    A=3,
    B=5,
    C=12,
    D=22,
    E=48,
} index;
// this array is a lookup table: it shall be indexed by letters starting with 'A'
// and contains the enum value associated with each letter
index lut['Z'-'A'+1] = {A,B,C,D,E, ...};
// if this is the input string and the ouput array
char  string[21]= "AAABBBCCDDDDDEABDECD";
index lind[21];  // adjust the size of this array, or allocate it dynamically to suit your needs
// now conversion takes the form of
unsigned int i = 0;
while ( string[i] != '\0' )
    if ( (string[i] < 'A') && (string[i] > 'Z') )  // you shall always verify user input !
        exit( -1 );                                // take appropriate actions in case of input error
    lind[i] = lut[ string[i]-'A' ];
    i++;
there can be a great number of variations on this code: using string replace functions of the standard library, using characters pointers to factorout the index of the string, etc...
anyway, i fear that you got your problem wrong. what you are writing looks a lot like a parser: a user provides an input that you read and convert to something useful for your program. if the input string is given by a user, this solution works (while there may be a more extensible solution). remember, that user input shall always be validated, and error checking code might take a lot more than the single line in the example above because a parser has to be fool-proof and fail gracefully in case of error. however, if the input string is coded in your own program, then this approach is definitely bad: inefficient, error prone, the solution does not represent the problem space. if you tell us more about your program, we would be able to tell you more about a solution.
(3,873 Views)
Thank you! It is the solution! I probalby had the 'writer's block' creeping on me, you knocked me out of it 🙂
layosh
(3,851 Views)
