LabWindows/CVI
Is it possible to use *.a static library files in CVI on Windows?
Hi!
I need to use some third-party code in my program, and I have managed to compile it into a *.a static library file (not *.lib). Is it possible for me to make use of the *.a file or do I need to use *.lib if I develop on Windows?
Thanks!
(2,021 Views)
Accepted by guybrush_threepwood
No. A .a library is a Linux static library and won't run on Windows.. You need to compile you library on Windows, possibly with CVI but any compiler will do.
(1,979 Views)
Actually, any compiler will do is a bit of a stretch. The compiler should be able to generate proper COFF format object files in order to be able to link them with the LabWindows/CVI linker. While COFF is the defacto standard under Windows nowadays since the demise of Borland C, Symantec C and other derived compilers which used the competing OMF object format, it's still not a completely idiot proof experiences if you use gcc based compiler tools as even if you create COFF object files, they don't have to be necessarily in an MSVC compatible form.
Rolf Kalbermatter  My Blog
(1,973 Views)
Thanks to both of you! Very relevant to know about the COFF format as well. I might easily have stumbled on that one!
(1,930 Views)
