LabWindows/CVI
Is it possible using SCAN funciton to preform this string.
I have this string  LocalLogPath,"c:\log"
i want separate this one to two buff like this . buff1="LocalLogpath"; buff2 = "c:\log".
i use below function.
Scan (tempBuff1, "%s>%s[xt44]%s", tempBuff2,tempBuff3);
then i got tempbuff2="LocalLogpath" , tempBuff3 = ","c:\log""  however , the red parts on tempBuff3 is not really i want.
So i want to know is it possible to have my expected result with scan funciton only. or i should write extra function to preform this?
Gerry
(3,052 Views)
To correctly separate this string you could use a slightly more complicated format string applying the "terminate on" modifier more than once:
Scan (tempBuff1, "%s[xt44]%s[dxt34]%s[xt34]", tempBuff2, tempBuff3);
Message Edited by Roberto Bozzolo on 12-25-2006 10:47 PM
(3,045 Views)
Thanks a lot! I have solved this problem with you suggestion !  ^_^
(3,040 Views)
