LabWindows/CVI
installing cvi 8.1
Hello
I just received my CVI 8.1upgrade CD.  Can I install this over my current CVI (8.0.1), or do I have to uninstall CVI 8.0.1 first?
Stuart Van Deusen
(3,675 Views)
You may install CVI 8.1 without uninstalling CVI 8.0.1.  Different versions of the CVI programming environment can remain installed side-by-side on your system.  If you only want one version of the environment on your system, you may uninstall CVI 8.0.1.
Regardless of the order in which you install/uninstall CVI you will always end up with the newest runtime engine on your system.
Hope this helps.
Mert A.
(3,671 Views)
Hello
I guess the more accurate question is, if I want only the most current version (8.1) on my computer, can I install 8.1 into the same location where 8.0.1 is located (what I refer to as "over"), or do I have to uninstall 8.0.1 first, then install 8.1?  If the latter, will I then have to reinstall add ons like the PID controller.
Thank you
Stuart Van Deusen
(3,670 Views)
It is a bad idea to install one version of CVI into the same directory as another version.  This effectively merges the two installations, even though your system considers them separate, distinct installations.  You should instead first uninstall CVI 8.0.1 or install CVI 8.1 to a new directory.  As a general rule, you should rerun any driver or toolkit installers whenever you install a new version of CVI to be sure everything works properly.  However, if you are installing CVI to the same directory as the old version, I believe you can get by without reinstalling your drivers/toolkits.  The driver/toolkit files should be left behind when CVI 8.0.1 uninstalls, and you should be able to install CVI 8.1 into the directory that gets left behind.
As a side note, just in case you are using the CVI RT module, you do not want to uninstall CVI 8.0.1 quite yet.  The CVI RT 8.0 module is only compatible with the CVI 8.0.x environment.  As the CVI RT 8.1 module has not yet been released, you must continue to use CVI 8.0.1 if you want to target RT systems.
Let me know if you run into any issues.
Mert A.
(3,660 Views)
Thank you.  I'll post again if I have any problems with the upgrade.
Stuart Van Deusen
(3,652 Views)
