LabWindows/CVI
Is the Measurement Studio a MS SourceSave Compliant product?
What type of code version protection is National Instruments using? I want to protect the versions of codewriting I do in CVI, so incase I hose a program, I can always back up a verson or two. So MS Visual Source Save requirments are: "SCC-compliant" or "SourceSafe compliant." http://msdn.microsoft.com/ssafe/ >> http://msdn.microsoft.com/ssafe/technical/documentation.asp
(3,232 Views)
LabWindows/CVI 5.5 and higher uses the source code control integration API and should work with most third-party SCC products including Visual Source Safe. In addition, the CVI R&D group has tested with Visual Source Safe.
Jeremiah Cox
http://www.ni.com/ask
(3,232 Views)
