LabWindows/CVI
the choosen cell
i try to get with cell was click in the EVENT_LEFT_CLICK
so i use
GetTableCellFromPoint (panel, control, MakePoint(eventData1, eventData2),&the_point);
like this
and always the_point is (0,0)
why does not it return the correct cell ?
(3,228 Views)
Hi !
There's a guy with the same problem. His question (the name is heedone) was posted on 4/26/2001 and answered by Chris Matthews on 4/26/2001.
You should be able to find that answer.
I attached the question below.
Hope I could help you
Nose
"I want to get the indices of a cell which is clicked by mouse. I used the
GetTableCellFromPoint() function but it doesn't work well. If I click the
cell(2,4), it returns (0,0). Please tell me about the solution for the problem. If
you have any idea, please let me know it. Thank you"
(3,228 Views)
Hanan,
You need to invert the order of the coordinates you are passing to MakePoint.
eventData1 is the vertical (y-axis) position of the mouse and eventData2 is the horizontal (x-axis) position of the mouse. So you function should include MakePoint(evenData2, eventData1).
Best Regards,
Azucena Perez
(3,228 Views)
