LabWindows/CVI
Is there a quick way to clear, delete data from a Table?
I would like to click on a button "Clear Data" and go and delete entire data from a table...
Thanks in advance-
(3,854 Views)
Here's one way.
int CVICALLBACK ClearTable (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
int RowCount;
switch (event)
case EVENT_COMMIT:
GetNumTableRows (panelHandle, PANEL_TABLE, &RowCount);
if (RowCount > 0) {
DeleteTableColumns (panelHandle, PANEL_TABLE, 1, -1);
DeleteTableRows (panelHandle, PANEL_TABLE, 1, -1);
break;
return 0;
(3,854 Views)
This actually deletes the rows and columns, not just the data. You'll need to InsertTableColumns() and InsertTableRows() to rebuild the table.
(3,854 Views)
The best way to do this is by calling FillTableCellRange. Just be sure you create different ranges whenever the cell type in your table changes. If all cells are of the same type, then you only need to do this once.
(3,854 Views)
DeleteTableRows() is all I needed.
Thanks-
(3,854 Views)
