LabWindows/CVI
Is there a way to build a distribution from a batch file?
I know we can build our executibles from a batch file.  I would also like to build the distribution from a batch file since our quality folks want to do the entire software build from batch files.  Is there a way to build a distribution from a batch file?
wswong.
(3,502 Views)
 i do not known if there is batch command.
 But LabWindows(7.1) has Activex control that does it
 try create ActiveX controller by wizard(from Tools menu) for "NI Labwindows/CVI Server" and check for function  CVI_AppCreateDistributionKit (CAObjHandle objectHandle, ERRORINFO errorInfo, long *returnValue);
i think you can create you own commandline application as you needs
//i am sory for my bad english
(3,482 Views)
Thank you for the suggestion.  I did not know that was an option.
(3,447 Views)
