Hi everyone,
I actually developp a numeric keyboard emulation and I would like to emulate the behavior of the Windows calculator for the sign changed. I explain the purpose : I would like to change the sign of the numeric input when I stroke a own defined image button (+/-). Is there a another solution that to allocate dynamically a variable with the same type as the UIR numeric input and use the minus operator to change the sign...
Thank you for your answer,
Jean-Noel Pomies
