LabWindows/CVI
Is there a way to change the sign of a numeric number by sending a specific keyboard code (like in Windows Calculator)
Hi everyone,
I actually developp a numeric keyboard emulation and I would like to emulate the behavior of the Windows calculator for the sign changed. I explain the purpose : I would like to change the sign of the numeric input when I stroke a own defined image button (+/-). Is there a another solution that to allocate dynamically a variable with the same type as the UIR numeric input and use the minus operator to change the sign...
Thank you for your answer,
Jean-Noel Pomies
(2,839 Views)
Within the callback for the numeric control, you could trap the EVENT_KEYPRESS event and check that the key pressed was the one you have assigned the +/- operation to. It is then a simple matter to negate the value held in the control.
JR
(2,833 Views)
